Welded Differential *Pics*
Old 09-13-2009, 03:15 PM
Cr8zyDrifter's Avatar
All of that . . .
EDIT:
Dude you're in TEXAS?!?! The drift scene out there is HUGE as is the tuner market. I have a few friends out there and a TON of drifting buddies. You should just get with the local drift scene and see if:
1. Any of them can get you hooked up or have a spare welded diff.
2. Any local shops can clean that up and/or get you setup with another diff, because that one is going to (as Scott already said) cause you issues.
I'm in the panhandle of texas, I think the drift scene is all south of me and its closer to drive to oklahoma or new mexico and than it is to south central texas, well from where im located. I think in this whole city, there are about 5 modded 240's not much of anykind of scene around here. Thanks for everyone's input. I think I'll try another one or just buy a LSD.
Cr8zyDrifter is offline
Old 09-13-2009, 03:33 PM
Originally Posted by 240smoke
they actually melt the gears together.
that's when you know the welds should hold, the term is penetration. the welds in the first pics appear to be just superficial and are likely to flake off under minimal stress.
jramosthe1st! is offline
Old 09-13-2009, 04:29 PM
USMCDrifter's Avatar
Hehehehehehe. . . penetration . . .
USMCDrifter is offline
Old 09-14-2009, 04:19 AM
David....... most guys can't afford a LSD... I know I couldn't around the time I welded mine. To me it's the first step to getting out there and doing it.
How many times have you heard "I don't have the right equipment" Ill also tell you a FULL 2way gives the same hopping, popping and scrubbing noise during daily driving. Yes the decel from lift off is dramatically better etc but.. they are not that far apart lol.
Biggamehit is offline
Old 09-14-2009, 11:45 AM
FuriousZ's Avatar
I agree
FuriousZ is offline
Old 09-14-2009, 12:10 PM
Nickmerrone's Avatar
get the hicas vlsd. thats what i have and my car kicks out so easily. its all the fun of a welded diff..with out the loud ghetto part.. :P
Nickmerrone is offline
Old 09-14-2009, 01:58 PM
I actually agree here. . .
A VLSD, when properly maintained and upkept (which really isn't that much work) is a LOT of fun and will work just as well as a friction-based limited slip.
Old 09-14-2009, 02:09 PM
wow..you mean someone agrees with me for once? haha.
Old 09-14-2009, 03:14 PM
im running a j30 vlsd and i love it but then again i dont drift and i imagine that the stress of drifting would roast the diff lol
battosaii930 is offline
Old 09-14-2009, 04:12 PM
hatrick6's Avatar
That doesnt look that good man. you need a high powered welder and you need to melt those gears together. Also you need to get all those welding beads out of there so they dont get jammed in the yoke and chip the gear.
+1, those welding beads can cause some damage, and no that weld doesn't work very strong, I through in a couple bolts when I weld a diff. Grab yourself another open diff (you can get one for like $50 used) and try it again with a more professional job.
hatrick6 is offline
Old 09-14-2009, 05:26 PM
  #26
240smoke's Avatar
The welds I had done were on a welder that ran on 480Volts. The thing was as big as my car. I am not afraid of them breaking. The axles or u-joints will give out before the welds will.
240smoke is offline
Old 09-15-2009, 01:17 AM
  #27
hhhaha yea.. when i welded mine the second time.. I had the dial cranked to the max. I seen the teeth melting... I gave out a evil laugh mmmmhmmhmhhmhhmhmmm haahahaahaha HAHAHAHAHAHAHA.
Old 09-15-2009, 08:18 AM
  #28
Old 09-15-2009, 08:51 AM
  #29
exactly hahahaa.
Old 09-15-2009, 01:15 PM
  #30
240smoke's Avatar
hahaha, destroying stuff for a greater cause is awesome.
240smoke is offline
aurora61
01-10-2007 11:40 AM
aztectt
04-18-2006 05:52 PM
rhapsody
09-19-2004 11:41 PM
needasr20
05-23-2004 10:43 AM
Quick Reply: Welded Differential *Pics*
