Swap is complete....LS6 V8 240sx
Old 02-13-2008, 07:18 PM
  #46
OutToWinPAHC's Avatar
I got some heads, a few set actually, I am doing the 5 lug swap and big brake upgrade now . I am using the Z33 track rotors upfront. And I got some nice new leather seats from a J30 in it and some engine management electroncs.... Its coming along.
One its done for the street I am gonna work on forced induction
OutToWinPAHC is offline
Old 02-13-2008, 09:54 PM
  #47
So are the seats as comfy as you had wanted them to be?
ryguy is offline
Old 02-14-2008, 06:24 PM
  #48
NiSmO Knight's Avatar
What bracket kit are you using for the Z33 rotors? And are you using the Z32 or R32 calipers?
NiSmO Knight is offline
Old 02-15-2008, 01:59 AM
  #49
240SS's Avatar
Looks good man.
Also if your interested in doing A/C I think Im going to tackle it on my motor soon. From the research Ive done the 240sx uses the same signals as the LSx and those gen motors. So it should be easy to wire just need to have adapter lines from the compressor to the condensor and then to the fire wall. Im going to run the 240 canister I think as long as the LS pressure sensor will fit.
240SS is offline
Old 02-15-2008, 04:41 PM
  #50
The seats are really nice, stiff, but for the money (30 bucks), they are awesome.
I am using wht R1 Wurks Z33 brackets with Z32 30mm calipers, OEM brembo rotors, and Hawk pads.
Yeah NOw that I look at it I could have kept the AC, but now I have more room to fit my turbo when I get to it.
Old 02-15-2008, 06:57 PM
  #51
Have a link to them brackets? I'm running on warped R32 GTR rotors right now, not fun hitting up the touge runs the way they shimmy my steering wheel. I'm surprised that I'm able to drive with them.
Old 02-15-2008, 09:49 PM
  #52
These are similar
http://cgi.ebay.com/ebaymotors/240SX...spagenameZWDVW
Old 04-25-2008, 06:15 PM
  #53
Just a little update. I have the motor ripped down right now. And I am doing a complete top end upgrade with tuning.
CNC port and polished heads, cam, lifters, pushrods, injectors, upgraded intake, ported oil pump. Im not going to give the specs but she will be making approx 510-525HP at the Flywheel and 450-480 rear wheels
Old 04-25-2008, 06:33 PM
  #54
damn good stuff.. have you dynoed your current setup
Biggamehit is offline
Old 04-25-2008, 07:54 PM
  #55
franspurs22's Avatar
i just came
franspurs22 is offline
Old 04-26-2008, 06:02 PM
  #56
Not since June, did about 370's RW with some bolt on, the fuel system upgrade, and WO exhaust. But im going from a cam lift of in the .470's to 603/609
Old 05-08-2008, 12:29 PM
  #57
snatch's Avatar
im plannin somethin like this for my s14. looks hot.
snatch is offline
Old 05-10-2008, 07:35 PM
  #58
BADA$$240's Avatar
I used to want a lsx swap until I started my RB30/26 project. It lays down a better torque curve than any lsx engine and makes about 480rwhp at 12psi with all stock internals. And if u wanna get crazy just up the boost to 22psi to lay down about 760rwhp. Eatin lsx's all day.
BADA$$240 is offline
Old 05-11-2008, 12:11 AM
  #59
its always easy to to talk big game.... but remember the LSX x not meaning a # can handle 2500 HP..... eating rb's all day
Old 05-11-2008, 04:06 PM
  #60
Both sides can make good points, bottom line is the owners personal preference of engine and the use.
I've seen RB's handle well over 1000 hp easy and LS_ engines handle just as much and a little more.
Again, this is where it becomes a preference and application decision and not who is better in numbers.
Quick Reply: Swap is complete....LS6 V8 240sx
