KA-T Memebers Setup/Specs/Tune info
^^ welll i drove from southern maryland to philly. i left on a full tank and got there with an half tank in full in and out of boost
base timing for an ka is 20* in order to set it properly you must follow the steps in the FSM which is to alow the engine to idle for a set amount of time rev it, unplug the TPS etc...........
after you have done all of that you loosen the 12mm bolts on the dizzy and with your timing light set it to 20* while your car is in N/A form....
after you install the turbo then you retard the timing... you can get an timing light for about 40 bucks at an auto store. 15*to 18* is what many guys with low psi setups are running.. again what i use my car for an how i use it doesnt demand some larger than life turbo with ungodly amounts of boost.
once again s14's use active type ecus, it is really important to only retard timing in boost. I never said you did it impropperly, it's just that getting the s14 ecu to work with your ka-t setup without it doing really funky things. is no easy task. I don't doubt that you keep track of how well the car runs with a wideband or that you check for knock, but for s14 guys is totally a different game. Even with a very mild setup fuel and timing management should be taken very seriously. Plus, I'm not really a fan of having my car idle like it has high lift cams when it doesn't
and spence have you seen the gadget on ka-t called the timing lock or sumthing like that, its still in testing but...should come soon enough. what do you think about that?
i know OBDII guys who went back to OBD1...... its totally up to you..
they had to swap engine harnesses, ecu, intake manifolds etc, but the money you would spend, you could just by the damn timing management or get an JWT ecu or Bikirom tune.
you can run an s13 ecu on an s14, you will have to change the primary o2 sensor and probably the mafs (you would upgrade that anyways though). there is also someone kinda local to me working on s14 obd2 drop in tunes. www.dl-tuning.com
all s14 ecus are active type, regardless of obd series. you can buy s14 to s13 conversion harnesses online. scott enthalpy supplies them with his tunes for the s14 chassis but i doubt he will sell the harness without buying the $500 tune.
#27
if its that easy how come the obd11 folks just do that? or is there more to it?
#28
you would be okay retarding the base timing a few degrees, and an msd btm would be an okay solution, but really it still pays off in the end to go with a full stand alone or even a simple rom tune. you still have to worry about the obd scanning, but as long as your emissions sytem is still in tact you should pass the sniffer. Luckily I don't have to worry about emissions at my inspection station. basically horn and lights and i'm out of there.
