Need Help Please
Old 01-06-2010, 02:19 PM
crazydrifter's Avatar
Need Help Please
So I havent been on this site since I sold my other 240 but I got another one awhile ago and I got some stuff for xmas and need the help form club240 again haha.
Alrighty I got an Apexi SafcII for xmas but I didnt get any instructions or manuels so Ive been searching the web for install instructions and I need some confirmation.
I have a 93 240 with the ka24 and heres what I have for the install so far...
SafcII----------------- Ka24de ECU(wire color and pinout)
Red- Power------------ B/R #36
Green-RPM Sig--------- Y/R #2
Gray- Throttle Sig------ W #30
Brown- Ground--------- ? same wire as safc black
Black- Ground---------- ? same wire as safc brown
Yellow- A/F(to ecu)---- W #16
White- A/F(away ecu)-- W #16
Blue- O2 sensor-------- ?
Pink-Not Used -
Orange-Not Used -
Purple- Knock---------- W#27
If anyone could check this out and make sure its right or confirm wire colors and pinout that would be awesome. I have a n62 maf thats going in with this too just to let you guys know.
Ill have a build thread later on after I clean it up and stuff.
Thanks and its great to be back!
crazydrifter is offline
Old 01-12-2010, 03:05 PM
Still havent found much on this, but i have found this http://www.redlinemotive.com/part-nu...on/bf08031.asp
its pricey but its an answer...
Old 01-13-2010, 05:18 AM
its the same as wiring it to an sr... you just have to consult you fsm and verify your points.
Biggamehit is offline
Old 01-15-2010, 12:16 PM
BurninRubb3r's Avatar
+1 for boomslang. They are great people over there who make amazing products.
BurninRubb3r is offline
Old 03-31-2010, 09:25 AM
Finally got the safc hooked up buuuuuuut..... my car wont start now haha. i bought it used and had to change the in and out setting (changed it to 5 in 5 out havent hooked up any other maf, was just making sure it worked) and the car will crank but not turn over. I took it off to make sure it wasnt my car messing up but it started right up. My guess is the setting thats saved on there is really wrong for my car, so my question is, Is there a way to reset the safcII and if not what are the original or factory settings?
Thanks
Old 04-02-2010, 10:42 AM
So I have searched and played with just about all settings on the safc but my car still will not start....
Anybody have any ideas or know how to reset these things???
Old 04-02-2010, 08:30 PM
SmokedZenki's Avatar
well sorry bud i wish i knew cause i plan on getting one of these... i wish someone would start a write up on the install and how to fine tune for dummies lol hint hint to anyone out there that wants tooo!!!!
Eric
SmokedZenki is offline
Old 04-05-2010, 08:29 PM
I am still puzzled by this, all the gauges on it work and the throttle position sensor but the car just wont start. If you find anything let me know!
Old 04-05-2010, 09:19 PM
There are start up settings for the SAFC .. however use them at your own risk.
Please check out the SAFC section for those settings bro... the SAFC has a CMOS type battery inside of it... open it up and remove the battery to clear all settings.... That will still leave you at stage one and I dont suggest it... you must set your in and out settings and your maf MUST be on.
Old 04-06-2010, 06:32 AM
I have seen a bunch of start up settings on here and other sites but they are all for the n60 or n62 maf and I still have my stock maf installed.
I REALLY dont want to open it up but I might just hook up my n60 maf and try messing with it again.
Thanks
japporeyser
04-07-2004 08:15 PM
90two4tsx
10-20-2003 01:16 PM
Daemos
08-31-2003 01:24 PM
Damicci
08-24-2003 08:24 AM
Bryan
07-19-2003 12:23 AM
Quick Reply: Need Help Please
