S-AFC on OBD-2?
You can use an SAFC on an OBD2 the difficulty is that at the time of adjusting an A/Fr OBD 2 ecu's continually shift there A/Fr's to driver habit's making it a bit more difficult to tune. It is doable, but it takes many more hours of tuning than OBD1.
But the tuning does take slightly longer on OBD2 rather than OBD1, correct? that was the only point I was trying to make. The AFR's on OBD1 are pretty much set for an easy correction, OBD2 seems to readjust it's afr's.
You are correct, a little longer, but after you hit a certain point, the OBD2 will stop trying to readjust the AFRs. This is when you are on the ragged edge of lean, but make the most power.
Driftin RPS13
06-01-2004 10:30 PM
