Old 01-15-2008, 08:29 PM
  #31
where did u get those hoses when i put my sr in i did some ghetto **** and the hoses ended up getting kinked and i had no heater i found this out when it got cold
i want to do it right this time so everything works
battosaii930 is offline
Old 01-15-2008, 09:29 PM
  #32
HeavyThrottle sells a heater hose kit.
Old 01-16-2008, 07:26 AM
  #33
Engine Bay Painting
I finally cleaned out and painted my engine bay yesterday. Earlier in the week I went in, taped things off, yanked old clips, removed old bolts, washed and wiped and removed any components that I could to avoid bagging them up.
I used Duplicolor...
low gloss black.
Pulled the lower engine harness.
Removed the coolant tank resevoir, P/S resevoir and fuse blocks.
Bagged vital things off.
Before.
After.
Before.
After.
Old 01-16-2008, 08:26 AM
  #34
Bumnah's Avatar
dope sauce.
i did the gto bushing as well.
try to score a HICAS front rack if you can. it's worth the headache.
Bumnah is offline
Old 01-16-2008, 08:56 AM
  #35
Originally Posted by Bumnah
dope sauce.
Thanks and what are the benefits of a HICAS front rack? Pardon my ignorance but I know nothing about the HICAS system. Time for some search and read.
Old 01-16-2008, 11:22 AM
  #36
Ran into a problem today, I was trying to put together and mount my powersteering bracket and pump and found that they don't fit together. I read on the forums that you can use the DOHC KA power steering pump with the SR power steering pump bracket...well I went to mount mine together and put them on the block and they will not work together. I found out earlier that I received a HICAS SR power steering pump so would it be that the SR HICAS pumps and the regular SR pumps have different brackets?
My KA P/S pump and bracket on the left and the SR HICAS P/S pump and bracket on the right.
Here I have the SR HICAS bracket on the left and as you can see the KA will not fit in that mounting location, it's a tad too long or the mounting location is a tad too short.
So I guess my question is does anyone know if a regular 2wd SR P/S bracket is different from the HICAS bracket and will it mount on my KA P/S pump?
Old 01-17-2008, 11:18 AM
  #37
Does anyone know what this thing is and where it goes?
Old 01-17-2008, 11:57 AM
  #38
Bumnah's Avatar
regular 2ws front rack = 17:1 ratio
hicas front rack = 14.7:1 ratio. faster.
racks are interchangeable.
Bumnah is offline
Old 01-17-2008, 12:16 PM
  #39
Bumnah's Avatar
i asked durdan about your ps problem. his reply:
durdan: remove pump
durdan: undo back 4 bolts
durdan: pull off rear pump cover
durdan: remove metal vane plates
durdan: reassemble pump
durdan: block of rear pump outlet fitting
durdan: now you have a normal pump
(using the hicas pump on your non hicas car without needing anything different)
Bumnah is offline
Old 01-17-2008, 12:54 PM
  #40
looks like the little breather thing that hooks on the hose coming out of the tranny
motegineon is offline
Old 01-18-2008, 06:11 AM
  #41
durdan: remove pump
Sweet! I'm gonna get on that. Thanks to Bumnah and Durdan. Also thanks to motegineon, I would have never remembered where that part went.
Old 01-20-2008, 07:42 AM
  #42
Thanks for the tips, went to the KA and here is where the "thingy" goes. On the transmission like everyone said.Name:  crap.gif
Old 01-20-2008, 08:19 AM
  #43
This Just In!!!
I'm gonna follow Bumnah's path so I got a OEM sidemount intercooler and I'm gonna partner that with a aftermarket hotpipe and b.o.v.
Everythings intact and I got all the hardware.
Cleaned it up a bit.
Permacool fan and Koyo radiator.
Cometic headgasket...I'm scared to put this thing on though.
Can't put this stuff on until I get other stuff so I'm playing the waiting game.....
Old 01-20-2008, 09:14 AM
  #44
looking good bro.... you will sleep easy knowing the condition of your motor is in better shape.. good stuff man.
Biggamehit is offline
Old 01-20-2008, 09:36 AM
  #45
bay looks pretty good. when you plan to drop thing in?
MS!3 is offline
Quick Reply: My S13 SR20DET Prep
