RB20DET Clips for SALE
Old 12-02-2002, 01:18 AM
NightXCZ77's Avatar
Hey guys,
I have done the RB swap into a 240SX. My car is a 91 with the RB25DET engine. I like helping people out doing the swap as well as making the engines and parts available for those engines.
The RB swap is a little harder than the SR swap, but not by much and they require little modifications to your car that don't cost anything.
I am selling two clips right now for this swap. I just need to get rid of them. With buying a clip comes all of the info on how to do it and what is involved. Here are the specs on the clips (half cuts):
$1800
R31 (with transplanted R32) RB20DET - 220 HP 2.0L Inline 6 with turbo. Comes with Engine, Tranny, ECU, Un-cut Harness, Dash, Gauges etc...
Approx. 40,000 miles
$2100
R31 above + the rear suspension assembly and driveline. (first come first serve on the driveline since I only have 1)
$2250
R32 RB20DET - 220 HP 2.0L Inline 6 with turbo. Comes with Engine, Tranny, ECU, Downpipe, Un-cut Harness, Dash, Gauges etc... Approx. 40,000 miles
$2500
R32 above + rear suspension assembly and driveline. (first come first serve on the driveline since I only have 1)
NightXCZ77 is offline
Old 12-03-2002, 12:17 PM
RedStage's Avatar
Pls Check your e-mail
Sent you some info in regards to the R31 engines.
Meant to help, might not have come out like that.
RedStage is offline
Old 12-03-2002, 12:23 PM
NightXCZ77's Avatar
hey
Marc,
Thanks for the heads up. True, the SR can do good things with enough money, but that's the problem....enough money. RB engines don't take much to get that high, and it costs a lot less to do it. As well, you mentioned that you've seen a number of good tuned SR's take a mildy tuned GTR's, point is, they were mildly tuned. Also, GTR's weigh quite a bit more than the 180SX, when you throw the Skyline engine in the 180....you get a lot better results.
Night
Old 12-10-2002, 07:54 PM
Mafioso's Avatar
So how hard would it be to fit an rb26dett into an s14?
Mafioso is offline
Old 12-10-2002, 09:48 PM
NightXCZ77's Avatar
RB26
It's a pretty hard swap due to steering, if you go to a single turbo upgrade on the RB26DETT, it wouldn't be too hard.
Night
Old 12-10-2002, 10:00 PM
Mafioso's Avatar
What's the steering problem?
Mafioso is offline
Old 12-10-2002, 10:05 PM
suckit's Avatar
Turbo hits the steering shaft proably cause it sits too far back. Also why a big turbo kit from Japan migh not clear a 240 cause it sits too far back where there is no cloumn on a JDM Silvia.
suckit is offline
Old 12-10-2002, 10:32 PM
Mafioso's Avatar
No way around it cept for single turbo conversion? Losing out if it switches to single instead of twin?
Mafioso is offline
Old 12-10-2002, 10:42 PM
AceInHole's Avatar
a lot of the upgrades are to a larger single turbo. in a way, you'd have more to gain than to lose in going to a single turbo.
AceInHole is offline
Old 12-10-2002, 11:57 PM
NightXCZ77's Avatar
The second turbo is in the way of the steering column that attaches to your steering rack assembly. The downpipe of this turbo it the main thing in the way. By doing a single turbo upgrade, you move the turbo into the middle of the six exhaust ports so you don't have the problem with the steering column hitting.
Night
Old 12-11-2002, 12:01 AM
Mafioso's Avatar
So what's the main difference from the rb26dett and the rb25det.. besides twin turbo and the .1 litre difference..
Mafioso is offline
Old 12-11-2002, 12:06 AM
NightXCZ77's Avatar
diff
The difference between the two is one less turbo, .1 L less, .5 higher compression ratio, and a different stroke. Also, the RB26DETT has a large intake manifold with independant throttle bodies, larger injectors, and a better built head.
RB26 = 276 hp
RB25 = 250 hp
Night
Old 12-11-2002, 12:36 AM
Mafioso's Avatar
So without the twin turbo.. I'd do a single turbo.. and installation would be easy or somwhat easy?
Mafioso is offline
Old 12-11-2002, 01:47 AM
NightXCZ77's Avatar
Exactly....
Night
Old 12-11-2002, 04:52 AM
NightSlide Josh's Avatar
dont you also need to use the 2.5 tranny on the 2.6 cuz its awd?
NightSlide Josh is offline
Quick Reply: RB20DET Clips for SALE
