Go Back   S-Chassis.com > General Discussions > How Tos / Installations
New! Use your Facebook to securely log into this site, click logo to login
Thread Tools Display Modes
Old 02-19-2009, 06:08 AM   #166
Biggamehit
Personal Sales Rating: (2)
Drives: 89 KA-T 240sx/ 94 R33 Nissan Skyline
Send a message via AIM to Biggamehit Send a message via MSN to Biggamehit Send a message via Yahoo to Biggamehit
yes sir there is.
Biggamehit is offline   Reply With Quote
Old 02-19-2009, 07:59 PM   #167
bucket240
Personal Sales Rating: (0)
bucket240's Avatar
I just removed the gauges again and there is no way in hell that I can remove the blue film. Maybe on just a s13 but not on a s14.
__________________
ZENKI 4 LIFE
bucket240 is offline   Reply With Quote
Old 02-19-2009, 08:59 PM   #168
Biggamehit
you have to take the cluster apart.
Old 02-20-2009, 05:46 AM   #169
bucket240
bucket240's Avatar
I did take the cluster apart and got down to just the gauge. The gauge itself is made of blue plastic, I also noticed that my s14 gauge is different from other s14 gauges, I have a 95 non se. But I did sand down the back of the gauge with some fine sandpaper, it made the numbers a little brighter.
__________________
ZENKI 4 LIFE
Old 04-07-2009, 07:49 PM   #170
DisFrikkenWill
Quote:
Originally Posted by Biggamehit View Post
yeaup you need the 360 deg light.. it shines in all directions not just straight ahead.
Just to clarify before I buy some for my s14 cluster
so I buy these ones?
WLED Miniature Wedge Base bulbs
with High Power SMD LEDs - 360 type
T3-1/4 (#194/168) type bulbs with High Power SMD
Wide Angle LEDs radially mounted emitting 360 degrees
Replaces: 194, 158, 168, 12256, 12961 - 12 Volt DC operation
and 1 of these for the clock?
#74 Instrument Panel
and Gauge LED bulbs
T1-3/4 bulbs with standard LED or High Power SMD LED
are also available without the Twist-Lock holder
Replaces: 17 18 37 70 73 79 85 86 2721 - 12 Volt DC operation
DisFrikkenWill is offline   Reply With Quote
Old 01-28-2010, 08:18 PM   #171
japanesenut
japanesenut's Avatar
Drives: nissan 240sx
Well did my gauges today and did the s13 silvia cluster change with the 180mph mod and boy do i love it .
__________________
E85 S13.4 FINISHED AND WOW
12.96@109 with 14psi of boost UN TUNED .
Mods so far .To many more to put down
Exedy Stage 2 clutch / Greddy ras /ss clutch line
kaaz 2.0 lsd/ ss power steering line
17x9 xxt962 , z32 front brake upgrade done for 2010.
Treadstone variable boost controller
Aem wide band /glow shift gauges
Garrett t3/t4 turbo / Ceramic Coated Peak boost Mani
japanesenut is offline   Reply With Quote
Old 01-28-2010, 09:23 PM   #172
1SXY240
Drives: 1995 Nissan 240SX SE
180mph mod? how do you do that? I have never heard of it before
__________________
Shift_[DRFT]
1SXY240 is offline   Reply With Quote
Old 01-28-2010, 10:48 PM   #173
Biggamehit
you change the resistance or something like that and it will convert into MPH.
google it brother.
Old 04-20-2010, 03:36 PM   #174
NismoHead90
NismoHead90's Avatar
Drives: 1990 240sx
i checked this write up on MNR, good ****, i ordered mine, was blue the right ones to get for that look ^^^
__________________
"Burn Rubber, not your soul"
NismoHead90 is offline   Reply With Quote
Old 04-22-2010, 10:10 PM   #175
NismoHead90
Drives: 1990 240sx
this is also my install..2 things: 1 my gauges cut on when i turn the ignition 2 my right needle isn't getting light
__________________
Old 04-23-2010, 11:08 AM   #176
Biggamehit
looks good.
Old 04-26-2010, 06:12 AM   #177
justgotta240
justgotta240's Avatar
Drives: 1989 240sx/1993 engine
so i was thinking about doing this today but u said if you put on a new gas gauge bulb it stays on im gonna do red so how would i do that like i dont want all red then a white gas gauge
justgotta240 is offline   Reply With Quote
Old 04-26-2010, 04:17 PM   #178
lifted&lowered
Drives: 240sx
I have green in mine. ill take pictures tonightand post them. I also got the turn signal's blue. they look sweet
lifted&lowered is offline   Reply With Quote
Old 04-30-2010, 05:57 AM   #179
Biggamehit
hahah blue is popular it seems
Old 05-01-2010, 02:05 PM   #180
Cr8zyDrifter
Cr8zyDrifter's Avatar
Drives: Nissan MotherF******240 S13
my middle light went out, I don't know if it burned out or just came loose. Haven't wanted to take the dash apart again.
__________________
93' S13 Hatch
Cr8zyDrifter is offline   Reply With Quote
Tags
240sx, 300zx, clusted, cluster, coupe, gauge, guage, guages, led, leds, na, plastic, removal, s13, write
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
  Click here to find out more!
S-Chassis.com - Archive -
Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
