Lug Nuts In Stock @ 201 Motorsports
Lug Nuts @ 201 Motorsports
Muteki Lightweight Short Lug Nuts (Closed End & Open End)
Price: $45 shipped
Muteki Lightweight Open End Extended SR48 Lug Nuts
Price: $58 shipped
Muteki Lightweight Open End Extended SR48 Lug Nuts (Neo Chrono)
Price: $100 shipped
Work Lightweight Closed End Duranium Short Lug Nuts
Price: $125 shipped
The Muteki Wheel Lugs are shaped in a heptagonal pattern making each a seven sided lug nut. Muteki nuts look like an ordinary lug nut from a distance, but the only way that you can remove the Muteki lugs is with the special socket ONLY provided with the set. You'll get added security for your rims. The Muteki lugs also weigh 50% less than stock lug nuts (0.9 oz. vs. 2.1 oz.) On a car with 4 Muteki lugs per wheel, this can save you more than a pound! These Muteki lug nuts are open ended to comply with most race sanctioning bodies and can be used for everyday driving.
The latest lug nuts from Wheelmate of Japan, the SR48 Lug Nuts come in a set of 20 with key adapter. Made of durable chrome vanadium, each lug weighs in at a mere 2 oz! They're also open ended, making them easily adaptable for short or extended wheel stud usage.
The latest lug nuts from Wheelmate of Japan, the Muteki SR48 Lug Nuts come in a set of 20 with key adapter. Made of durable chrome vanadium, each lug weighs in at a mere 2 oz! They're also open ended, making them easily adaptable for short or extended wheel stud usage. Super light-weight thin-wall contruction using strong CHROME VANADIUM 28DCRVM SPEC.
WORK Light Weight Racing Lug Nuts.
Make by Duranium material. Extremely light weight. Come in 20 pieces per set including 4 locking nuts.
Available in M12 x 1.25 or M12 x 1.5
Available in Red or Blue Only
I will definitely hit you up end of this week for the lug nuts, but boo for not having extended studs! LOL
I guess I'll just keep looking for the studs, I was just hoping that I could kill 2 birds with one stone so to speak.
Let me see if I can dig something up for you, it never hurts to try!
Problem solved, I just added the option to choose closed or open end for the Muteki Thank you!
Hey Phil, Just took a peek at Ichiba's site, they do have the 50 mm studs with a 14mm & 12.75 knurl. Could you order me 10 of each? Sorry bout not sending my payment yet, didnt have time to deposit $ into my account over the weekend. But for sure, I'll send you the $ for the studs and lug nuts. Oh and I wanted the short open ended Muteki's in black.
Could you also check on pricing for the following rims:
Sport Max 006 18x9.5J (their site says they have a 3.5" lip)
Sport Max 009 18x9.5J (also 3.5" lip)
MB Battle 17x9.5J (+15 offset)
Thanks in advance!
Thanks in advance!
