bypassing amp
ok i kno everyone says to take out the factory amp. so i did that and i kinda forgot you had to bypass it. i searched around in a few forums and googled, but i was unable to find out how exactly to by pass it. which wires? if someone could point me in the right direction id be most grateful.
EDIT: hey Mika if you can contact me via AIM (bangkeirabang) before you bypass the amps, I'd appreciate it.
- Raine Pull the amps and you'll get the following (quick and dirty): 1 Blue left front speaker neg. input 2 Black right front speaker pos. input 3 Blue/yellow left front speaker neg. output 4 Brown/white right front speaker neg. output 5 Brown right front speaker pos. output 6 Pink left front speaker pos. input 7 White right front speaker neg. input 8 Blue/white left front speaker pos. output 9 Blue acc. 10 Green/red on/off 11 Purple left rear speaker neg. input 12 Pink right rear speaker neg. input 13 Green left rear speaker neg. output 14 Pink right rear speaker neg. output 15 Blue right rear speaker pos. output 16 reen left rear speaker pos. inpu 17 Blue right rearspeaker pos. input 18 Red left rear speaker pos. output 19 Blue acc 20 Green/red on/off Now splice the following wires together: 1 to 3 2 to 5 4 to 7 6 to 8 11 to 13 12 to 14 15 to 17 16 to 18 This is originally on **********, I might make it easier to read sometime in the future |
