Disabling the stock alarm?
Old Mar 8, 2005 | 10:16 PM
Matthew_aka_Mat's Avatar
Since nobody seems to be responding to this in thread I found in the general discussion forum, I thought I should go ahead and ask my question in the correct forum.
My roommate has a 1995 240SX SE with a schizophrenic alarm. The sensors may be going bad, because the alarm goes off all the time even if nobody touches the car. As a temporary fix, we have disconnected the horn, but he still can't start the car if it is spazing out at the time. Is there any way to completely disable the alarm? Or even just remove the part that disables the ignition?
edit: I guess another good question to ask is: Any idea what it would take to find out exactly what is wrong and just fix the alarm? (I think alarms in general are useless, but I guess one that only goes off when it needs to is better than one that always goes off.)
Thanks,
Matt
Old Mar 9, 2005 | 03:46 PM
95_240SXSE's Avatar
Well to disable it, you can just pull the fuse which I believe is in the fuse box in the right side of the engine bay. As for fixing it, I'm guessing there might be a short in the system.
Old Mar 9, 2005 | 03:50 PM
Thanks, I'll try pulling that fuse and see if it will disable the alarm, but not disable the car.
Old Mar 10, 2005 | 03:53 PM
JonathanRuiz's Avatar
i have the same problem with my car.
I have the same problem with my car and i need to know how to fix it. When it goes off it pisses everyone off that lives in the dorms. lol
Old Mar 14, 2005 | 09:37 AM
Ghettostamps's Avatar
Re: i have the same problem with my car.
So your that guy...
Old Apr 12, 2005 | 07:05 PM
LA_phantom_240's Avatar
Re: Re: i have the same problem with my car.
Originally posted by Ghettostamps
So your that guy...
LOL
Temporary
Mar 10, 2005 10:49 PM
Infamous Silvia
Jan 7, 2004 09:07 PM
Import Fanatix
Nov 12, 2002 05:09 AM
kimcheeracing
Nov 11, 2002 03:11 AM
