Help!!!
Well im installing my new deck which is a Pioneer FH-p700 custon fit deck. It power up and everything the problem is when it up to the stock speakers it doesnt play but when i hook the deck into some portible speaker they work fine so i was wondering if theres soomething wrong with the stock speaker since they worked with my stocked deck.
Re: Help!!!
Originally posted by mike2o6 Well im installing my new deck which is a Pioneer FH-p700 custon fit deck. It power up and everything the problem is when it up to the stock speakers it doesnt play but when i hook the deck into some portible speaker they work fine so i was wondering if theres soomething wrong with the stock speaker since they worked with my stocked deck. they aren't wired correctly....did you buy a wire harness kit? |
no bu I will soon ill stop by best buys today and get em
well got the harness in but still doesnt work so i decided to take out the rear speaker and test em there fine I think i might have some kinda wiring problem can any one give me any more advice before i decided to rewire my car
Might be amplified?
:nono: Im a moble installer for best buy and the problem ive seen is you might have a amplified sys in your car the amps should be under the rear deck lid. If you re-wire from the amps back to the deck you shouldnt have a problem.
| All times are GMT -7. The time now is 02:14 AM. |
