help installing radio needed
i just bought a kenwood KDC-135 CD receiver and ive tried so many combinations connecting the wires. but i just cant get the thing to turn on.
i have a nissan 240sx 89 or 90 not sure right now but i got the KA24E engine in there and im wondering any of you guys can help me out in getting it to work. please i need much help with this trying to get it done by monday or tuesday. |
connect both switched and constant wires.. some of the newer radios take more power than the old.
check your ground as well.
Did you get a wire harness adaptor for this unit? Most units I've installed come with a color code for all the wires. Usually, the harness adaptor will take care of it all, but not sure if your car still has the factory plug.
I know it may sound stupid, but check the fuses. ALL OF THEM.
ok i install these for my job, first get urself a harness then check and see if u can get a "smart cable" for ur deck. those will let u just plug and play no need to cut strip or solder. if that dosent work i would recomend taking to a local circuit city or best buy to have a re wire done
You may want to check a wiring diagram. Do you still have the factory harness attached, or has that been hacked off?
Like Ryguy said, check all your fuses. If you're trying different wiring combonations, more than likely you have grounded a +12v source. Constant +12v is what's needed to get your radio to turn on. |
(Post 334560)
:dunno: |
Just splice them if you have a wiring diagram. Extend them if you need to.
| All times are GMT -7. The time now is 07:22 AM. |
