Lowering powerantenna??
Hey guys I bought my s13 with a sony cd player that was connected poorly(never turns off), and the antenna is always up I would really like it all the way down and well hidden I never listen to the radio so if you guys know how I could probably just jump the wires to make it go down that would be really great.
your power antenna will never go down unless your stereo turns off. try and run new wires with fuses from your ignition harness. you will need 12v and an acc. wire. if you hook thenm up properly yyour stereo will shut of f with the car and your antenna will lower. if it doesnt check the wiring at the antenna.
NissanLunatic
Feb 8, 2002 07:10 AM
