mounting stuff
I'm installing a security system and am having trouble deciding where to mount the brain and shock sensors. if anyone has a system installed i would appreciate it if you could tell me where the sensors and brain were mounted if you know. Thanks
the brain for mine is under the steering column, don't know about sensors or anything...
I installed the brain of my alarm on the firewall.
Yes - behind the dash, deep in there where you can't get to it without pulling the whole dash out. Try disabling that compared to the easy harness pull from under the steering column (sorry s13240, lol) Shock senor in turn was mounted high up near the base of the windshield on either end of the car (I have 2). $0.02 |
^im assuming you had take out the dash to get back there? howd you run all the wiring? hidden?
Originally posted by l2aine Yes - behind the dash, deep in there where you can't get to it without pulling the whole dash out. Try disabling that compared to the easy harness pull from under the steering column (sorry s13240, lol) |
Thanks for the replys. it will be lots of help whenever i finally get around to doing it.
Wonder if anyone has seen a guide with pictures on installing a system?
| All times are GMT -7. The time now is 08:36 AM. |
