programming 2 OEM keyless remotes
I have searched the board and found how to program one OEM keyless remote but have not been able to successfully program 2 remotes to work on the same car. Does anyone know how to do this? Thanks. By the way, the car is a 95.
if you know how to program then i'll skip to the last part. when you hit the button on the remote and the lights flash you should then lock and unlock the door then hit the button on the next remote. then turn key to off position and test it
When relocking the doors to program the second remote, do I lock and unlock the doors using the electronic switch on the door itself, or by using the thing to unlock just the drivers door, or by using the buttons on the remote? Thanks for your help.
I have tried what you said over and over and can't seem to get the second remote programmed. Am I supposed to take the key out after I program the first remote then relock and reinsert key or what? I don't know what else it could be. Any help would be great. Thanks.
SilviaS14KA24DE
Feb 21, 2009 02:23 PM
