S14- stock tweeters
OK I did a search and came up empty. Does anyone know of specfic brand/size tweeters to install in factory location (on the pillar)?
brand is whatever. As for size, I replaced mine with Polks, which are about 1" in diameter and 3/4" high when surface mounted. If you remove the bracket that holds the factory tweeter in there, you get a little more depth to use for clearance.
kool, thats what i needed to know. when I pulled off my cover I saw the bracket with a spec of a tweet in there. I wasn't sure if any normal tweet would fit.
