Speakers for my 24sx
Old Jul 13, 2004 | 03:55 PM
haran's Avatar
Question Speakers for my 24sx
wazzzzup ppl..I am gonna change my factory speakers in my 240sx but can't decide on which one.. can someone plz help me..??? thanks!
help me chosse one from the following below:
Detailed Description of the XSW4621:
Sony XS-W4621 4x6" 2-Way Speakers (Pair)
4x6" Polypropylene Woofer cone
1 1/8" Film Cone Tweeter
120W peak power (20W RMS)
Direct, drop in replacement for 4x6" factory equipped speakers
Flexible, Multi-fit mounting system
Priced per pair
Sony 1-Year Warranty
Detailed Description of the TS-G4640R:
Pioneer TS-G4640R
4"x6" 2-way speakers
injection-molded polypropylene (IMPP) composite woofer
1-3/8" PET silver film cone tweeter
fits both standard 4"x6" and metric 4"x6"m openings
frequency response 45-22,000 Hz
recommended power range 2-20 watts RMS
peak power handling 100 watts
sensitivity 90 dB
top-mount depth 1-11/16"
Detailed Description of the EX462A:
POLK AUDIO EX462A
Mineral filled polymer composites for smooth response
Butyl rubber driver surrounds for better performance and greater reliability
Ferro-magnetic fluid cooled tweeters for high SPL
Multi hole mounting pattern and low profile design ensure easy fit in virtually any factory location
Woofer 1 - 4" x 6", Polymer composite cone with rubber surround
Tweeter 1 - 1/2" Diameter, Dome Tweeter
Power Handling (continuous): 70W
Overall Frequency Response: 95hz-22khz
Nominal Impedance: 4 ohms
Efficiency: 91 dB
Driver Complement Woofer: 4" x 6" (10cm x 16cm) woofer Tweeter: 1/2" (1.2cm) dome tweeter Woofer Mounting Depth: Top Mount 1 3/8" (3.5cm)
Frequency Response: 95Hz - 22kHz
Sensitivity: 91dB
Power Rating: 70 watts max
any help is appreciated...as I am confussed on which to get ..
Old Jul 13, 2004 | 04:30 PM
LTSCUDRFT's Avatar
no speakers they add weight
Old Jul 13, 2004 | 04:58 PM
haran's Avatar
oh don't worry abt that, as the car will be doing a lot of runs.. thus it will be in shape!!
Old Jul 14, 2004 | 08:16 PM
I'm with Stupid's Avatar
I had the older pioneer ts-g4647 in my old 240, which look like almost like the same speaker as the ts-g4640r. I thought they were pretty good speakers. In my car now, I have alpine sps-460a speakers which I think sound a bit clearer overall, especially in the high frequencies. I'd still recommend the pioneers though, if that's any help.
Old Jul 14, 2004 | 08:26 PM
RandyJordan's Avatar
hmmm...its all up to ur budget...thats it...
if you got money to waste then go for whatever the most expensive is.
Old Jul 14, 2004 | 08:53 PM
haran's Avatar
thanks guys .. I think I will go with the TS-G4640R as I found one for like 30 dollars..
Old Jul 15, 2004 | 12:37 PM
turtle's Avatar
depends wat your set up is. . if u want to have subs. get something wit a clear sound such as the new "power" for fosgate or infinity kappas. if u want decent speakers for not to much get the pioneers.. they are cheap but sound decent -=D
Old Jul 16, 2004 | 11:46 AM
GFinger240's Avatar
if you haven't bought your speakers yet, here is an idea: instead of going with litle 4x6" speakers, take out the enclosure for the speakers, make a 1/2" thick MDF template, and put a 6.5" speaker in the door. This way, you have a larger selection of speakers, as 6.5" is the most common speaker size, and they can handle more power, and since its a round speaker, it will sound better than a oval.
Old Jul 30, 2004 | 12:08 PM
I got Pioneer's which sound pretty good.
Old Jul 30, 2004 | 01:27 PM
haran's Avatar
I got the pioneer toooooo..and its soundss greatttttttt
Old Jul 31, 2004 | 04:17 PM
PIONEER!!
Old Aug 3, 2004 | 09:14 AM
look at this site for some cheap prices--->discount jungle
Old Apr 18, 2005 | 07:10 PM
LA_phantom_240's Avatar
ALPINE type s components own all.. and on ebay you can get em for under 100 bucks
Old Apr 19, 2005 | 02:59 AM
wikd240's Avatar
put the alpine up against a set of focal or diamond audio speakers to see which own... i agree with the 6.5 in speakers in the doors... it takes some work but well worth it when it comes to sound...
the weight issue is an interesting thing... if you remove the stock amps (if you have the active speaker system) the amp in each door has about the same weight as a speaker... so take that out rewire the stereo and you are still at the same weight...
Old Apr 19, 2005 | 02:23 PM
Diamond audio? Ive seen them before, but never really heard of them... saw em on ebay and were cheap, so i thought they were some cheap knockoff brand...kinda like how pep boys stocks "dual" a.k.a. the worst speakers money can buy
