Wiring Diagram
What up everyone! I need some help....Anyone kno where i can get a wiring Diagram for My Car (1990 240SX Fastback)...it really important cuz i need one so i can put in my alarm.....
thanks guyz....
Re: Wiring Diagram
thanks guyz....
thanks guyz....
12volts
white
ignition harness
Starter black/white + ignition harness
Ignition black/red + ignition harness
Power Lock orange/black F driver kick panel
Power Unlock same wire
Lock Motor none non none
Unlock Motor none non none
Disarm Defeat none non none
Parking Lights+ red/blue back of dash dimmer
Parking Lights- none
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger red/white - courtesy light
Dome Supervision none non none
Trunk/Hatch Pin red - sw. or light in trunk
Hood Pin none
Trunk/Hatch Release none
Power Sliding Door
Factory Alarm Arm none
Factory Alarm Disarm none
Disarm No Unlock none non none
Tachometer yellow/red AC ECM pass. kick panel
Horn Trigger green/white - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer By Pass : Not Available
DOOR LOCK NOTE:
This is one of the three known systems Nissan used in early production. To operate, open(cut) the org/blk wire and the doors will lock, pulse the same wire to ground and the doors unlock. The other two systems are negative pulse (orange/black for lock and orange/blue for unlock both at the door lock timer in the passenger kick behind the ecm.) and non-centralized - add actuator in drivers door.
MAKE : NISSAN | MODEL : 240SX | YEAR : 1990
* The logo is registered trade mark of Nissan Corporate.
