Who wants to guess how fast I went at the track???
Here's the deal. I will tell you everything you want to know/ask about the car, and you guess how fast it made it down the 1/4 mile.
The things that are in BOLD are what I think should most effect the decision. AMS/Turbo240 Crate Motor -Arias 8.8:1 forged pistons (stock bore) -AMS Sportsman Rods -Calico Main and Rod Bearings -Fully grooved bearings -AMS ARP Main stud Kit -AMS 11mm Head stud kit -Thread-sert 11mm anchors for head studs -Properly shimmed and clearanced oil pump -New AMS OEM timing chain assemblies -Stock valves -Supertech Dual springs w/ titanium retainers -Crower v3 cams (not degreed and yet they still work...) -O-ring block deck surface -Fel-Pro Head Gasket AMS/Turbo240 Turbo kit -AMS GT33 turbo -AMS tubular bottom mount t3 header -TiAL 44mm wastegate -AMS wastegate dump tube -AMS downpipe -AmS spec oil feed and return -Medium Precision FMIC -Custom AMS IC piping -Apex-i N1 exhaust w/ test pipe AMS/Turbo240 Fuel system -Walbro 255 fuel pump -75lb injectors -Fuel Lab Rising Rate FPR -300zx TT fuel filter -Mitsubishi Injector Resistor pack -Liquid filled fuel pressure gauge AMS/Turbo240 Pre-production Intake Manifold -Stock Throttle body Igniton -Taylor Wires -NGK BKR7E -Stock coil -Stock distributor Engine Management -AEM EMS -AEM Boost control Solenoid -AEM 5 bar map sensor -GM IAT AMS Evo Small Battery kit -Modified to fit in 240sx Cooling -Koyo Radiator -Altima fans -Greddy HP radiator cap Driveline -AMS C4 transmission kit with transbrake -1pc steel driveshaft Wheels and Tires -Weld Drag lites (4 lug baby) -26x10 MT ET Drags -Ivan's Bogart skinny's up front Thats it! guess away! If you need to know anything else about the car to make your educated decision, feel free to ask![/b] |
im going to make an uneducated guess 12.6 sec.
im gonna go with 12.1 give or take the 0.1/
11.8.....?
Are you guys nuts?
low 9s Maybe high 8s? |
im guessing 9.5
so who wins?
To relieve everyone of their suspense:
1.41 60 foot 105 mph in the 1/8 10.31 @ 131 in the 1/4 One of these days I will get the video out. It looks awesome coming out of the hole. |
mmmmmm thats tasty
I saw a video that said 9.15, was that the 1/8 mile? |
^^^ that was prob Ivan.
Not bad, i bet it felt nice!
haha **** that was Ivan's video I saw. I thought there was only one drag 240 at AMS. How embarrassing.... :bluecrying:
Man, that was sweet. What drag strip was it at? And was that the prototype intake, because I thought somebody said somewhere that the hood would close over it on the production one.
By the way, you should host it on youtube or something like that so you don't have to unarchive the file. |
it says Great Lakes Dragway, Uniongrove WI.....in the video
edit..that car sounds like a monster..good work man |
