1st Gear
I changed my transmission fluid about 500 miles ago, and ever since then I have been having trouble getting it in to first gear, if I am moving whatsoever it sticks at first and just feels really $#@!ty. Has anyone else experienced this problem? Or have a suggestion on what the cause might be?
What transmission oil did you use? Some have additives that eat bronze synchros like the ones in the 240's tranny.
-Justin |
Originally posted by Justin.b What transmission oil did you use? Some have additives that eat bronze synchros like the ones in the 240's tranny. -Justin Should we just use the oil from the dealership? I would like something that can take some more abuse. Or should I go with the stock stuff and just change it a lot more? |
I'm trying to remember myself.... It's a certain rating. I knew it a month ago but now I'm drawing a blank. I know that Redline MTL and MT90 are different and one is godd, but the other is bad.
OK, the more I type, the sillier I sound so I'll get the actual info and post it. -Justin |
I used mobil 1 synthetic gear lube.
Another thing, if I was wrecking the syncros wouldnt the gears grind?? Cuz that doesnt happen, its just sticks a little when i try to get it in gear.
i thought Mobil 1 was supposed to be good oil :dunno:
If one of those is bad it aint the redline. Redline is the sh!znit
