90 300z vlsd into 240sx
i got a 300z rear end diff and i was wondering DO I USE THE STOCK 240 FLANGES ON THE LSD. IF NOT WHAT DO I USE
Dude...search. With 4 seconds of searching i found this http://www.club240.com/forums/showth...highlight=vlsd
i saw that but all i says about the flanges is u have to get new one i was wondering if u swap them with the 240s
You need to use 240sx VLSD output flanges...which can be very costly. OR buy pre95 J30 axles and that will probably be cheaper. Ive heard you can also use regualr 240sx flanges, but machine them down a little so they can fit.
what part of the output flanges
need to be machined
I wish i knew :confused: All i know is you gatta make it shorter
do u think the 300z axles or just the part that bolts onto the lsd and use the 240 axles and slide it into the 300z axle cup
Originally posted by bonomo just the part that bolts onto the lsd and use the 240 axles and slide it into the 300z axle cup |
