auto to manual help
i have a couple of questions before i start my auto to manual swap. my car is a 95 s14 auto obd1 the car i picked up is a 91 s13 5speed obd1(im pretty sure they are)
my questions are, 1. will the drive shaft from the manual match up to my s14 or do i have to get a m/t drive shaft from a s14 to make it work, 2. im almost positive that the clutch pedal will match up but just want to make sure, 3. any difference in any clutch lines or mounts, xmember anything else at all that i should know about, should i not do this and look for a 95 manual to swap with, any advice will be great, i have read some of the threads on how to do this and trust me will be next to me every step of the way,but any extra advice will be great, thanks a lot josh(my s14) |
1) you will need the s14 manual Dshaft
2) might as well try 3) The X member might be different, the rest should be the same. |
