-   Drivetrain (https://www.s-chassis.com/forums/drivetrain-14/)
-   -   automatic transmission bushing (https://www.s-chassis.com/forums/drivetrain-14/automatic-transmission-bushing-33959/)
91s13hatch Jul 29, 2006 11:51 AM
ok well i bought a 91 240sx it didnt run at the time and i thought it had a blown head gasket but when i pulled the motor i found two holes in the side of the block. so i bought a used dual cam motor from a guy that did my friends sr swap. the motor was an automatic and the guy said i would have to change a few things but nothing major. so today i tried for a couple of hours and many trips the the autoparts store to try and get the automatic bushing out of the crank so i can put the manual one in. i have tried slide hammers and bearing pullers with no luck. . the pullers didnt work because there isnt enough lip on the bushing for the pullers to grab a hold of. so if there is any special trick or advice to pulling this out please let me know
nightkid86 Jul 31, 2006 08:46 AM
Dremel it out. Make slits down the sides and eventually it will crack in on itself. The one in my engine was stuck when I did a 5 speed coversion. major PITA.
I assume you already tried the grease and plunger method? It didn't work for me but it might work for you
91s13hatch Jul 31, 2006 06:46 PM
thanks man the plunger method was mentioned to me today by a friend but i appreciate it
nightkid86 Jul 31, 2006 07:13 PM
honestly if the puller tool didn't work I doubt the plunger will. but go for it. better than dremeling
Bryan Jul 31, 2006 07:41 PM
Moving this to the "Drivetrain" section
