Best Lube For a Squeaky Clutch Pedal
I searched squeaky clutch pedal but no one stated what lube to use to silence the squeak...or does it really matter?
I just used one of those a tube of white lithium grease on all the moving parts and it stopped it just fine. But im sure you could using any type of grease and it would be fine.
i know what you mean mine did the same thing after i replaced the mc. i put some brake fluid on the rod and that did it.
Any type of grease will do, buy some moly grease and use it for EVERYTHING.
