-   Drivetrain (https://www.s-chassis.com/forums/drivetrain-14/)
-   -   Can an sr20 tranny fit on a ka24? (https://www.s-chassis.com/forums/drivetrain-14/can-sr20-tranny-fit-ka24-47430/)
NachtDerVampir Oct 11, 2011 05:25 PM
Im looking for a 5 speedtranny for my ka24 and the only **** i found was an sr20 tranny. Can that **** fit on my ka24?
Biggamehit Oct 16, 2011 07:12 AM
no sir it can not bolt to the engine but you swap the gear box
NachtDerVampir Oct 17, 2011 04:07 PM
And how about a ka24de transmission on a ka24e?
zenkisan33 Oct 21, 2011 04:31 PM
from what I've been told you need to change the bell housing and ta-da
Biggamehit Oct 22, 2011 03:07 PM
All KA transmissions can be used with each other.. however if you use a OBDII transmission from a later model you have to remove the CAS from the top center portion of the transmission before installing.
