-   Drivetrain (https://www.s-chassis.com/forums/drivetrain-14/)
-   -   car jerks with new lsd (https://www.s-chassis.com/forums/drivetrain-14/car-jerks-new-lsd-37106/)
aurora61 Jan 28, 2007 11:30 PM
i recently installed my tomei 2 way lsd...
However, my car seems to suddenly jerk while driving on straight-aways. This jerking is not constant, but happens every minute or so. This jerking seems to happen on higher rpms (maybe around 2500 and up), and it usually becomes fine in the lower rpms...especially cruising in 5th gear. Also, flooring the clutch to shift gears suddenly jerks the car. (The car jerks more right than left if that matters)
The installation of the lsd seemed to go pretty well, and i went through the initial break-in procedure involving doing figure-8s. I also changed the diff oil after the break-in. Also the differential pumpkin has no leaks. The alignment does not look bad either.
So does anybody have any ideas to fix this problem?
tehott240 Jan 29, 2007 10:47 AM
i cant remember but i think ther is like a torque adjustment on the diff. maybe something happened there
re037 Jan 29, 2007 05:38 PM
wheel bearings?
aurora61 Jan 29, 2007 10:20 PM
The wheel bearings are fine...
Mopotedbas Jan 29, 2007 10:28 PM
superb! :D ;) :D
http://nakedcamerondiaz.info/blog/comments/276827
regards, Mopotedbas
ryguy Jan 30, 2007 10:50 AM
^wow, i didnt read the web address. Fell right into that one. Its like a phucking spam landmine^
aurora61 Jan 30, 2007 11:44 AM
wats all that about...i cant watch that video, but i dont think i even want to...
NiSmO Knight Feb 21, 2007 01:26 PM
Check that, or to be on the safe side, contact a shop in your area that is very familiar with Tomei parts and see what they say. If they are a reputable shop, they will let you know whats up with out telling you to come in and pay X amount before they tell you whats wrong with it if it is the diff.
