Differential bushings
I have a 92 coupe with a sr redtop, aluminum driveshaft and 300zx lsd. I need new bushing for the diff because the ones I have are on my car are cracked, I was just wondering if anyone knew if the energy suspension master kit included these? And, if not, where I could buy them. thanks
Silvia20t |
you don't have diff bushings on an 92 bro.. thats only s14's you sure you looking at the right part. if that appears to be cracked, you have an issue and you need a new housing.
however if you have swapped out differentials and the housing that you are using has bushing just simply go to your local parts store and have them look up differential and the bushings will be available at last resort you may have to go to nissan and pay 20 dollars for a piece of rubber. |
I'll take a picture of what I'm talking about and post it later today, that might make it a little clearer.
are you talkin about the subframe bushings? btw damn airman jackson answering questions at 3 30 in the mornin lol
I need to have my car on a lift to get a good picture, the gas tank blocks any view. Are the subframe bushings on the differential? Or very close to it, Like right above or below?
He said he has a differential from a 300zx. They had differential bushings. Just google search "300zx differential bushing" and a bunch of results pop up. Heres one with Nismo bushings. http://www.nismoparts.com/catalog/?section=214
http://www.energysuspensionparts.com...sp?prod=7.1108
Thats what I'm looking for right? Were the bushings different from the NA and TT, or by year? |
