do i have an LSD???
i got the 90 240 earlier this week, got it in the driveway last night so today was the first i got to really check it out. i jacked up the rear and put it in gear then turned one wheel. the other turned in the oppisit direction. but in neutral olny one wheel spins. there isn't any where i can see that there is a sticker. so now what??? some one get at me so i can sleep easy or go buy one.
The only way you can have LSD is if you live in Canada, or have Super HICAS. If you don't have 4 way steering then no LSD.
when in gear the LSD will turn both wheels the same direction...if they turn opposite directions, you have an open diff.
-Rick |
understand?
You have a '90. That alone should tell you.
all-right i get the picture
Get a CDN rear and you will be straight. I have a link somewhere to a dude that sells them from rotor to rotor.
what the blood-clot is a CDN rear end? well if it locks up mine then show me the link! i found an lsd used for $200 will the CDN WORK BETTER?
CDN rear end = canadian rear end with axles do to all canadian 240s having limited slip
Originally posted by rudeboy what the blood-clot is a CDN rear end? well if it locks up mine then show me the link! i found an lsd used for $200 will the CDN WORK BETTER? Where is the rear end from? Are you garenteed that it is a VLSD? |
you don't have l.s.d you have to buy it
hey hows it going man nope your stock don't have lsd only jdm ones do
stanbo, i dont remember where that lsd i found is at. but when i requested the quote i asked for the lsd diff.
nismofreak72-dont forget about the canadians and those people who got the factory option. |
u can put a 300zx rear end in ur 240 it will match right up bc the 300 has lsd
oh boi...
i wouldnt try the z rear maybe a j30 rear |
There are many warnings of not using the 300z lsd unless you are making a great deal of power. The gear ratio is different from the 240sx.
