-   Drivetrain (https://www.s-chassis.com/forums/drivetrain-14/)
-   -   flywheel bolts (https://www.s-chassis.com/forums/drivetrain-14/flywheel-bolts-34534/)
ka-tdrift Aug 25, 2006 06:32 PM
flywheel bolts
im having a hard time getting my flywheel bolts out i have tried everything i can think of anybody have any suggestions
RuizXIII Aug 25, 2006 07:08 PM
Whats the problem tho, they are stuck and wont budge or is the flywheel rotating every time you try and ratchet ??
motegineon Aug 26, 2006 12:13 AM
get someone to hold something inbetween the teeth as you turn, use a breaker bar or something of that sort, they are torqued down to atleast 100lbs
2forties Aug 26, 2006 08:19 AM
I read somewhere that you should use a torch and heat them up before the go at them.
Preston Aug 26, 2006 08:27 AM
Impact gun?
papaganoushh Aug 26, 2006 11:02 AM
yea get someone to put someting in between the teeth or you can also get a flywheel tool from a local auto shop for pretty cheap
sbanzer123 Aug 26, 2006 11:15 AM
air impact +1
motegineon Aug 26, 2006 03:02 PM
Originally posted by sbanzer123
air impact +1
just dont put them back in that way
nismo24 owner Aug 27, 2006 12:58 AM
listen to motegineon impact out torck wrench in
ka-tdrift Aug 28, 2006 02:44 AM
thanks guys for the help. found out the guy that had the car b4 me was a hack so he did stuff half ass. turned out he torqued them to 150 ft/lbs so me and a buddy heated up the flywheel and they came out no problem :bigok:
