hicas or superhicas
is there away to install this amazing tech. into a 91 coupe ??
Re: hicas or superhicas
Originally posted by irax is there away to install this amazing tech. into a 91 coupe ?? Have you driven with it? |
no.. but i just wanted to know if it was possible..
Yeah it should be. I can't see why not the drivetrains are swappable. There might be a problem with mounting the rear steering rack but if you want it you can have it made to fit.
you need the whole rear subframe from a super hicas car aswell as the hicas pump and hicas steering pump and all the lines and so on. but yes it will go on with not too much headache. dont forget the speed sensors on the hubs and the front hubs aswell.
