Lsd
Lsd
the '91 super HICAS has an lsd, right? is it a 1 or 1.5 or 2 way? would it be worth it to upgrade to an aftermarket one such as a kaaz lsd (www.digitalracer.com)? if i do upgrade, would i be better off with a 1.5 way or a 2 way?
you need the shafts too b/c the american 240 has a different bolt pattern than the canadian 240.
i don't want to drift, i want to autoX. which lsd would be best or should i just leave the stock one in?
it would be better if you changed your LSD to after market. the stock one is a little weak. if you do get yourself a new lsd make sure its 1.5 way because it will help you hit the corners a lot better than a 2way. the 2 way will make you understeer alittle bit. trust me i have a 2 way and i drift, i like to auto-x sometimes just to collect the cones
call me the cone collecter! well yeah 2 way is not good if you are auto-xing.
peter
call me the cone collecter! well yeah 2 way is not good if you are auto-xing. peter
Originally posted by StanBo
What companies offer gear diffs? I heard they are better maintenance wise than disc style lsds.
Originally posted by spitz7985
kaaz offers gear types i believe
let me know if i'm wrong tho.
