-   Drivetrain (https://www.s-chassis.com/forums/drivetrain-14/)
-   -   Lsd (https://www.s-chassis.com/forums/drivetrain-14/lsd-607/)
Driftin180SX Mar 4, 2002 04:14 PM
Lsd
How do u kno if u have a LSD on ur 240 or not?
battlestylespl Mar 4, 2002 05:35 PM
do a burnout
Alias Mar 4, 2002 06:39 PM
lol excelent............
battlestylespl Mar 4, 2002 08:52 PM
1 Attachment(s)
here's an example
LSD
battlestylespl Mar 4, 2002 08:53 PM
1 Attachment(s)
no LSD
(my car)
Alias Mar 4, 2002 08:56 PM
wow, go thru alot of tires? LOL
battlestylespl Mar 4, 2002 09:04 PM
not really
Alias Mar 4, 2002 09:22 PM
didn't some of the 240's come with LSD's? lol I'm gonna goto a parking lot and do a nice burnout and see. :D BRB
battlestylespl Mar 4, 2002 11:29 PM
yeah...they have an orange tag on the diff. it's hard to see it though.
Silviaspeed Mar 5, 2002 03:15 PM
Also, if you have the rear end jacked up, just turn one of your tires in one direction. If the other tire spins the same way, you have LSD, if the other tire spins in the opposite direction, you don't have LSD.
Alias Mar 5, 2002 04:13 PM
Nope, no LSD here. LOL. Was it an Infiniti J30 that just bolts on? I gotta find a junkyard with one.
Silviaspeed Mar 5, 2002 07:11 PM
Depends though. From what I know, if you have an S14, a 95' and up J30 dif. will bolt right up. With an S13, the output flanges for the axles is of a different bolt pattern. The S14 uses a 2 bolt pattern:
The pairs of bolts are actually closer together than this, its the best I could do. Just look at the two bolts on top in the little diagram, and you'll get the idea.
As for the S13 I'm not sure because I have a 95'. Sorry.
Heres a link though.
http://www.**********/Images/bulletin.htm
Silviaspeed Mar 5, 2002 07:15 PM
Screw the diagram, its not showing the bolt pattern the way I set it up in my post............POS. Just check out the link I posted.
battlestylespl Mar 6, 2002 12:54 AM
http://www.**********/links/installs/lsd2/index.htm
http://www.**********/links/installs/lsd/lsd.htm
check out both of those links
altima/240sx Sep 19, 2002 09:24 PM
i have an 89 s13, where should i look to find a LSD cheap. I dont' know if getting it from canada is going to be cheap. But i know i need one.
