-   Drivetrain (https://www.s-chassis.com/forums/drivetrain-14/)
-   -   LSD or NOT? (https://www.s-chassis.com/forums/drivetrain-14/lsd-not-20882/)
AtlDrifter Mar 15, 2005 01:55 AM
LSD or NOT?
I just bought a 93 240sx SE and Im not sure if it has an LSD or not. When I do a burn out it lights up both rear wheels but when I go around a trun and and get on it only one spins. I have to double clutch it to get it sideways or hit second hard. Can someone tell me if I have an LSD or NOT?
smokie700 Mar 15, 2005 03:24 AM
Jack your car up and spin one of the rear tires if both spin the same direction then you have a lsd if one spins one way and the other spins different then you don't
By the way LSD is bad and illeagal hehe Im drizunk in this piece
Hagis Mar 16, 2005 03:49 PM
Unless somone already swapped out the factory diff, its not an LSD.
Bryan Mar 17, 2005 02:36 AM
search search search, someone asks this everyday and there is probably about 30 threads with the answer already
twofotisx Mar 17, 2005 05:06 AM
For a second I thought this was a question. Like should I get one if I have the money. Ok, if you have the money buy a good one like from Cusco or Nismo, and chances are extremely high that you don't have one unless the person who owned the 240sx before you was a big auto enthusist.
