manual swap wiring for 89 fastback
Hi,
I have done a manual swap on my car. I wired up my reverse light and got it to work. I only need to wire up my 5th gear sensor and my neutral gear sensor. I have done many searches on this forum and others and havent found anything for the 89-93 240sx. I only found wiring for the s14. I have used the s14 5spd swap guide that most people used, but The ecu wiring seems to have different colors the the wires on my ecu. Since its different, I cant locate my 5th gear sensor and my neutral position sensor on my ECU. Can somebody tell me where the 5th gear position sensor wire and the neutral position sensor wire are on my 89 240sx ecu, so I can have my 5spd tranny wiring completed? ~rich |
don't bother it just reactivates your speed limiter
| All times are GMT -7. The time now is 03:25 AM. |
