Need Help With Clutch!
my clutch on my 1992 s13 is screwed up i have to pump it every time. i need to shift. there is no pressure in it. i already tried bleeding the clutch line. nothing worked. i was also told to bypass the dampner loop
and bleed that. but i do not know how/where that is. someone please help a brother out. |
got o raines garage guides(sticky in the general section) to figure out the dampener line, which will help but is not your problem, try you clutch slave cylinder, it may be going out on you...
