| 240sxFan |
Sep 30, 2004 11:46 PM |
New Clutch slipping!??!
Hi! I just replaced my clutch not too long ago and it feels like it's slipping. When I shift gears in High RPM the engine revs up before the car beggins to actually move. I read the following diagnostic to test for slippage:
The clutch can also be checked in the service bay by setting the parking brake, chocking the wheels, putting the transmission into high gear and slowly releasing the clutch pedal (make sure nobody is standing in front of the vehicle when you do this!). If the engine stalls immediately, the clutch is not slipping. If the engine continues to run when the clutch pedal is fully released, the clutch is slipping badly and needs repair. If the engine slows, but continues to run, the clutch is slipping.
I did that, I put it on 5th gear, set the parking break and beggan to pull out the pedal. I pulled it almost all the way out before the car died. Did it again, I pulled almost all the way out, left there a bit and it still wouldn't die. The car kept on running barely, it was shacking a lot too. Can anyone gimme any more advice? Everything is new, disc, pressure place, got a flywheel resurfaced, what can it be? Thank you all:barf:
