no clutch pressure
Ok here is the deal my factory clutch wore out so i bought a stage 3 racing cluch bolted it to the fly wheel also i put in an nsk throwout dearing when i got it alll back together i went to bleed the clutch and never got a pedal i no im bleedin it right cause im a mechanic and so is my father but we cant fig out what the deal is does anyone have suggestions
Is your master or slave cylinders bad? Are you bleeding it from the slave and the damper loop?
no the slave and master cylinder are fine i even replaced the slave an still got nothing but i did notice that other bleeder and tried bleeding tht to is there some kind of way u gotta bleed both of these at the same time or in some kind of order to get all the air out thanks
I believe you bleed the damper loop first and then the slave.
i remember someone mentioning bleeding the damper with the front of the car raised. or you could just get rid of the damper :)
just make sure you bend the hardline slowly so you dont pinch it |
ok buddy imma try it and see wut happens il let u no how it goes
ok here is the deal i gotta my car running it drives an shifts jus fine put my pedal is jus sloppy as hell an dont come up all the way i think there is a cable i gotts tighten up imms do it tomorrow an by the way i love how the stage 3 clutch grabs
