-   Drivetrain (https://www.s-chassis.com/forums/drivetrain-14/)
-   -   problem with rear,LSD?? (https://www.s-chassis.com/forums/drivetrain-14/problem-rear-lsd-32134/)
Killer240SX Apr 24, 2006 04:38 PM
hey guys iam kinda new to the site and think i have a little problem with my rear. i saw a thread on how to see if i have a LSD on my car or not and it said to burn out and see if their are two tire marks or one. so i did and every time its different. some times two, some times one. also when i jack up the rear of the car and spin the tires. one spins but the other doesnt. from what i know (kinda new to RWD and LSD) if you spin one tire and they both turn the same way you have a LSD but if you spin one one way and the other goes the opposite direction you dont. also iam pretty sure that if it left two tire marks when i burn out some times theirs a chance i have a LSD but its just broke???? any help is greatly appreciated. Thanks
zenkislider Apr 24, 2006 06:33 PM
i think its if you spin it and both spin the same way you have a true 2 way diff. but if you spin one and the other goes the opposite direction you have a vlsd, and if you spin one and the other just doesnt spin you dont have an lsd of any sort,some one please correct me if im wrong
Bryan Apr 25, 2006 01:51 AM
Sounds like you don't have an LSD
Killer240SX Apr 25, 2006 06:13 AM
at first i didnt think i had a LSD but i thought it was almost imposible to burn out with both tires if you dont have a LSD. i can burn out and hold it and both will spin, then i will try it again and one will spin.
Preston Apr 25, 2006 06:53 AM
Open rear end can still get some power to the other wheel. It's just not a constant thing. That's why.
Waynehead05 Apr 25, 2006 02:07 PM
any lsd will spin both tires the same direction if it's an lsd.
zenkislider Apr 25, 2006 02:12 PM
what if its a vlsd, cause my bro has a vlsd and we jacked his car up and spun one and the other went in the opposite direction, thats why i think they both spin together only if you have a true 2 way or welded diff. ???
JDM_Freak May 1, 2006 05:47 PM
yeah im wondering the same thing, all i know is that my buddy welded his and that thing sucks to go around corners unless ur spinning the wheels. and forget about u-turns
Levi SPL S14 May 1, 2006 08:46 PM
You could have VLSD and its going out.
Open diff will NEVER leave 2 tire marks doing a burn out. it doesnt have the appropriate gears to do so.
Killer240SX May 2, 2006 09:03 PM
thats what iam thinking. could the clutch packs in side the rear be worn out??? also is their any way of tell if its a vlsd threw the vin # i tried the thread on decoding vin #'s but the link was bad.
zenkislider May 3, 2006 01:32 PM
l2aine is working on the site right now, try back when he is done
