-   Drivetrain (https://www.s-chassis.com/forums/drivetrain-14/)
-   -   s13 clutch, please hep (https://www.s-chassis.com/forums/drivetrain-14/s13-clutch-please-hep-44167/)
BigLee18 Jun 14, 2008 05:46 PM
i just bought this 1989 s13 recently and i thought the clutch failed on me. so i replace the clutch with an act clutch and thought everything was going to be ok. and then i bleed the system, but it still has this problem. when the car is off, i can put the car into any gear like nothing and when i push on the clutch pedal everything seems fine. when i turn the car on i can not put it into any gear and when i press the clutch pedal, it kind of rumbles and feels less stiff. what should i do to fix it? i need to fx it so i can drive becasue it doesnt let me go into any gear. so please help
thanks
Biggamehit Jun 14, 2008 05:48 PM
slave cylinder .................did you not change it if so thats your issue. nothing else
BigLee18 Jun 14, 2008 05:51 PM
i changed the slave cylinder before i replaced the clutch bwcause i thought that was the problem. any other options?
o.g.darkdrifter Jun 14, 2008 07:56 PM
Clutch...... pedal...... adjustment.
jramosthe1st! Jun 14, 2008 10:41 PM
i'd flush all the old fluid out, refill and bleed the system and see what that dose. old fluid tends to cause this problem along with a few others that can be avoided.
