-   Drivetrain (https://www.s-chassis.com/forums/drivetrain-14/)
-   -   s14 abs/lsd question (https://www.s-chassis.com/forums/drivetrain-14/s14-abs-lsd-question-15701/)
s14SE Sep 10, 2004 09:18 PM
Is it a good rule of thumb that if you have abs you should have the factory viscous lsd?
-HyJynX- Sep 11, 2004 11:50 AM
If you have ABS, you have a VLSD.
Krazyballa3 Sep 12, 2004 01:42 AM
if a 240 has abs... then does it mean it will have 5 lug wheels... or 4 lug wheels came with abs aswell?
-HyJynX- Sep 12, 2004 10:12 AM
Only SE and LE had the option for ABS, so if you had a sE or LE you would have 5 lugs.
Krazyballa3 Sep 18, 2004 12:32 AM
i see a lot of SE 240s with the non 5 spoke rims... and you can t tell it has 4 spoke or 5 spoke, i used to have the 5 spoke wheels on a SE so i know those are 5 spoke but i was just wondering all the SE with the non 5 spoke rims... if they had 5 lugs or 4 lugs... thanx for the input
