s14 driveshaft
Old Mar 17, 2005 | 02:28 PM
sifu's Avatar
s14 driveshaft
does it matter if the driveshaft has abs while my car doesnt? ABS has nothing to do with the driveshaft right?
Old Mar 18, 2005 | 06:22 AM
dacheat's Avatar
No, ABS has nothing to do with the drive shaft. ABS only relates to the brakes.
Old Apr 2, 2005 | 11:24 PM
bruinlax22's Avatar
not true
thats not entirely true, abs does have to do with the driveshaft, im putting together a 5 spd swap for my s14 with ABS and through my research, i've found that the abs and non-abs driveshafts are about an inch different in size so if you have an ABS car u need an ABS driveshaft and vice-versa, and used s14 abs driveshafts are impossible to find so it looks like i'll be going with a one-piece aluminum...hope this helps...
Old Apr 7, 2005 | 12:23 AM
tryiian's Avatar
why would the driveshaft matter in relation to the brakes? there`s the same amount of distance tween the trans and th diff with or without it, right? and the ABS wouldn`t have any components on the diff or axles, iWould assume.
Old Apr 8, 2005 | 07:06 AM
bruinlax22's Avatar
yup
didnt sound right to me either, but there is a difference in the two driveshafts of about an inch and the people that i've talked to about it before have done a bunch of 5 speed swaps so i trust 'em...
Old Apr 17, 2005 | 02:28 PM
advanced240's Avatar
ok, I will confirm that their is a difference between the shafts, but which shaft do i have? I have a 92 240sx-se with a 95 240sx motor swap, and now i am doing the sr20det black top swap but my drive shaft too long. I bought the car used with the swap"95 ka" already in. so i am at a loss on if i need a abs shaft or a non-abs? help..........
james_s14
Apr 12, 2005 04:21 PM
KuhnDawg
Apr 11, 2005 08:21 AM
KuhnDawg
Apr 11, 2005 12:08 AM
devnull
Dec 25, 2004 10:32 AM
brainfood
Jun 16, 2004 05:19 PM
