s15 lsd
will an s15 lsd fit into an s13....
thanks red |
Are you referring to the pumpkin? or just the "spool?"
i have a s13 with a open diff...will the s15 hlsd fit...what ouput shaft do i need...
ohh yeah...i just have the spool...will it still fit into the s13 open diff housing...
Please dont post twice in a row...just go back and edit your post
Originally posted by yiaracer ohh yeah...i just have the spool...will it still fit into the s13 open diff housing... |
where can i get some s15 helical lsd output shafts....
Well, you better have some hookups in Japan because dealer's here can't order them. Your best bet would be to keep looking at yahoo auctions, ebay, and www.jspec.com. They will not be cheap though.
according to what i found on jspec.com...the vlsd output shafts will work on the s15 helical lsd...
I believe that's a typo. I know who bought that off of jspec and they tried to use VLSD output shafts and it wouldn't work.
What is the difference between a VLSD and HLSD. I just installed a s15 subframe into my s13 it has a VLSD! I spin the wheel n the other one stays is that wrong? Did I get dicked?
http://auto.howstuffworks.com/differential9.htm
A good read. IIRC, S15s had a choice of Torsen(helical), VLSD and open. So there is a possibilty of you being dicked. |
Originally posted by GTP_Sil80 What is the difference between a VLSD and HLSD. I just installed a s15 subframe into my s13 it has a VLSD! I spin the wheel n the other one stays is that wrong? Did I get dicked? |
| All times are GMT -7. The time now is 07:09 AM. |
