shifter
granted i can shift real easy with my shifter butt it just dosent feel right its to slopy?
is there any way i can fix this? i did search but couldnt find what i was lookin for any one else have this problem? |
You can try getting a new shifter bushing thing (if you take out the shifter, its the little white piece that should be at the bottom. Also, your transmission mount may be jelly, may want to look into replacing it, it should get rid of some of the slop.
I had the same problem too. Then I bought a B&M short shifter. End of story. *hits the switch to deploy parachute* *cuts engine off* mods, lock thread please. No seriously though... you will not be dissapointed. Best money I've spend on my car to date
My friend has a b&m in his car and his throw is really short and looks smooth. I didn't have a chance to try it out. I have a knock-off short shifter and I'm going to be upgrading to the b&m because mine will pop out of reverse if I don't hold it in gear.
I have the B&M as well, and like they said it will fix any slop you have as it is very stiff, gets easier as it gets broken in of course. If you don't want a short shifter or want to spend that amount of money, I would look into the shifter bushing like I said first though.
thx guys so its a bushing at the end of the shifter gona see if i can pick one up at autozone or somewhere
