Simple S-14 question
I'm putting a 5sp in my s14. Do i need a manual ecu from another s14 or can i just bypass some stuff to my ecu ? thanks
Bypass nothing. The auto ECU will work fine, as if there was a manual ECU in there.
:EDIT: You will need to do minor re-wiring. Also, there will be CEL issues. There are a few write ups about it, just search "S14 transmission swap". |
everything should be covered here
http://www.club240.com/forums/showthread.php?t=33633 |
Thanks alot guys.
| All times are GMT -7. The time now is 06:00 AM. |
