Slave Cylinder?
Hey, this is a dumb question but im jus double checking, which one is the slave cylinder. Is it the small on on the far right of the engine bay? Or is it the bigger one?
That's the master clutch cylinder your talking about, slave cylinder is actually attached on to the Tranny, or right next to the tranny. Just follow the pressure line
Does anyone have like pic of the clutch master and slave cylinder. And like a detailed way to bleed the clutch lines, i have zero pressure on my pedal, its stuck to the floor. -HyJynX- sent me 2 pages out of a manual on how to do it but its kinda hard to understand. Thanks alot
Ok guys, i've found out what was wrong with the cluthc. I let someone borrow my car for quite a long time. Well i got it back when this happened. I checked the master cylinder and it was empy. So this would be the reason i have no pressure on the clutch right? So what do i do? Refill it and bleed it?? Someone help here i have to get it drivable before the end of the day.
| All times are GMT -7. The time now is 03:40 AM. |
