Slave cylinder
OK, so after installing a stage 2 clutch and starting my car again, after shifthing into first, the slave cylinder bursts. Im not sure if this has anthing to do with the throwout bearing problems im having, but now, the car wont start. Anybody have any idea whats up with my car?
what do u mean it bursts? like it blew up or what?
not even in neutral?
Did you bleed the clutch?
Several times i bled the clutch, but the end result was the same, trying to drive the car 3 ft forward, it popped out and all the clutch pressure was gone, because the fluid spilled out all the time.
just replace it then its only like $30 and you may also want to remove the clutch damper box if you have not done so already
