Swaping in lsd
I am going to pick up a super hicas diff assembly and i was wondering what do i need to make this all work in my 93 240sx hatch w/o abs? Can i just take my diff case and just put in the vlsd and just use my original axles and drive shaft?
Thanks |
I know this is off topic...but...
....with the right skill, it doesn't matter if you have ABS or not. Tsuchiya owns and drives an ABS-less brakes 553HP S15 on the track. |
Moved to suspension
I could be wrong on this...but aren't there some removable ABS rings where the half shafts are connected. |
....with the right skill, it doesn't matter if you have ABS or not. Tsuchiya owns and drives an ABS-less brakes 553HP S15 on the track. hah...yea and all of us here have the same lvl skill as tsuchiya... |
Is the out put shaft the same bolt pattern as my stock half shaft?
