Throwout bearings
When i'm shifting from 2 -> 3, when i press the clutch it makes a loose turning noise and same for when i depress the clutch.... one of my friends said that it may be the throw out bearings but he wasnt sure. is this something that i need to sweat or not really worry about until i do my engine swap and put in the new tranny??
cmon guys and gals i could really use the help here
sounds lke i could be, if your doing a swap soon i wouldnt worry about it unless its affecting your shifting
It could also be the hub that it runs on, it may need greased up a bit.
would i have 2 drop the tranny for that?
yea
forget that then. ill wait till i do my engine swap
lol:laugh:
If it is your throw out bearing, I'd get that fixed right away. bad throw out bear could cause clutch and pressure plate failure. My TO bearing was going. I told me friend, a Nissan Master tech, what was going on and thats what he told me. Get ti changed soon.
