tiptronic 6 speed for S15 SR20DET 240sx
Hey i have a 240sx 1993 i put in a S15 SR20DET Spec-R Silvia engine with turbo.
it is a 6 speed manual transmission. my question is does anyone know where i can get a custom or premade Tiptronic (autostick) transmission for my car with the engine im using. preferrably stick shift and not push button shift. 6 speed tho. thanx in advance |
is this possible?
an s-15 sr20det spec-r motor and a 6spd manual? GAH! why have i not seen others with this? |
Originally posted by audiophile is this possible? an s-15 sr20det spec-r motor and a 6spd manual? GAH! why have i not seen others with this? |
can i swap it into my s13 directly?
Why would you want Tiptronic? To take all the fun out of driving?
Originally posted by uofa240 Why would you want Tiptronic? To take all the fun out of driving? but to reiterate; can i directly swap in this majestic sr20det with a 6 speed manual? a 6 speed would be godly. |
I hear you can swap the six speed tranny with the older 5 speed sr20 trannys with no trouble, any body know about this?
Originally posted by audiophile can i swap it into my s13 directly? |
Originally posted by I'm with Stupid Yeah it's really easy, just more expensive. If you use the 6-speed, whether it's w/ a S15, S14, or S13 engine, you need to get the S15 differential as well beacause the speed sensor for the S15 is mounted on the diff. you will just have to do with out a Speedo. www.dennysdriveshaft.com builds custom driveshafts everyday. not only will you have a warrenty on breakage or twisting, you will free-up HP so it will bolt in like what...but keeping your speedo will take some custom know-how....feel me?:thumb: |
have fun with it. S15 swap is far from easy. you need the driveshaft and diff. the wiring is more complicated, and the diff will not bolt up. youd have to make custom output shafts. the 6-speed is NOT godly at all. its commonly swapped out for a 5-speed. and AFAIK you cant use the 6-speed with S13 or S14 SRs.
and why would you want tiptronic? thats super gay. |
